WebBrowser (size to portal?)
Postby kolemieux on Sat Jul 17, 2004 1:41 pm
Is there any option to allow the WebBrowser window to auto size to the portal window? Minus the scroll bars. I've seen several of the other HTPC browser pieces managing to do this - and in particular there are several "Spotlight apps" from MCE/BTV - Live365, Napster, Movielink, Cinemanow - that can snap right into Xlobby but really could benefit from the auto-size option. ESPN Motion as well....
I have a few local apps like this at well that don't work well unless they size to the window.
Any ideas on this one?
Thx
Chris
kolemieux
Postby Colby on Sun Mar 05, 2006 1:29 pm
if you still care, maybe xmovewindows plugin might accomplish what you are asking
