by Colby on Thu Sep 22, 2005 10:53 pm
create a folder database of your home movies. Label it whatever, be sure to put all the file extensions you wish in the import filter. Import the database. Then on the home movies, screen you will need to create a category, the references your newly created database. As far as having the items load with a specific player. If by default they load with that player in windows, I think the category execute will load the same. If you want specific file handling for certain file extensions you will need to setup that with the startup file handling or whatever its called. Jowaldo explains it I think.
Good luck.
