3 Zone Audio from 1 Creative soundcard
title says it all
Postby edgley on Wed Apr 28, 2004 1:47 pm
Hello,
I finally have got three zones from my Audigy.
You need the drivers from here:
http://kxproject.lugosoft.com/down.php?language=en
Once you have the full set, uninstall those lovely creative drivers, and install these.
Once alll the reboots have happened, its time to setup winamp.
If you go to the output section of the settings, and choose to configure the waveOut Output.
Under the Device drop down, you will see these (and maybe others):
kX Wave SB0090 10k2 [b800] 0/1
kX Wave SB0090 10k2 [b800] 4/5
kX Wave SB0090 10k2 [b800] 6/7
kX Wave SB0090 10k2 [b800] 8/9
The numbers might be different depending on the card you are using.
Each one of those lines represents a different output on the back of your card:
0/1 : all channel - NOT USED IN THIS SETUP
4/5 : front channels
6/7 : rear channels
8/9 : centre / sub
And by setting each instance of winamp to one of the above you can get three outputs from one card.
If it is not working, it will be down to the DSP router. I will post help for that next.
Simon.
edgley
Postby morpheus on Fri May 20, 2005 1:28 pm
Hi edgley
I downloaded the driver, but I wasn`t able to configure it. I have 4 "soundcarts" now, but when I select one I can?t hear anything on any output.
Would be very nice if you can show me your DSP settings.
Thanks for quick reply.
Morpheus
morpheus
Postby GFORCE on Wed Jun 08, 2005 1:57 pm
what card did you buy?
The Audigy2 Value?
GFORCE
Postby edgley on Wed Jun 08, 2005 8:57 pm
sorry, I missed this one.
I will try and do tonight, or tomorrow for you.
edgley
Postby GFORCE on Thu Jun 09, 2005 10:43 am
if you bought the audigy2 value, i will have to post my DSP Settings as the stanard settings dont work for mutlizone
GFORCE
Postby morpheus on Fri Jul 22, 2005 10:47 am
I got it :), but only for Winamp!
Zoomplayer doesn`t output with my DSP setup.(can select what I want)
So I bought an external SB Live and everything works fine. :)
thx cu
morpheus
Postby Lee on Wed Aug 03, 2005 12:49 pm
Edgely,
Do you know if the DSP settings you have will work for the SB live card?.
I have installed the KX drivers, and now have 4 sounds outputs shown within windows etc., and have configured the 3 winamp installations to use different outputs. But when I use any of the winamps, all of them play over 1 output on the card ( the front speaker output I think ).
Is there any chance you could explain wht to look for in the settings to set this up correctly, or post your DSP settings?
Many Thanks
Lee
Lee
Postby hjackson on Wed Sep 21, 2005 10:14 pm
Lee, did you ever get this working?
hjackson
hjackson
Postby Lee on Fri Sep 23, 2005 3:05 pm
No I haven't managed to get it working yet. To be honest I had a quick look at it when I saw the original post, but I haven't spent much time on it since then as I have been moving from Homeseer1.7 to Homeseer2.
Lee
Lee
Postby GFORCE on Tue Sep 27, 2005 2:10 am
its the way the dsp is setup
i had the same problems with the audigy2 value card
when i get home
GFORCE
Postby justchillinout on Thu Oct 13, 2005 3:27 pm
Has there been any progress on this? It seems like this thread has stalled. Which is unfortunate, because my installation of Xlobby has stalled without multi-zone working.
Does anybody have further information regarding the setup of the DSP Router? Is it possible for someone to post their router setup information?
GForce, are you able to help us out with this yet?
Any help would be appreciated.
justchillinout
Postby GFORCE on Fri Oct 14, 2005 6:10 am
I need to know what card you guys are tryng to use first.
If it is the Audigy2 Value SB0400 I can give you the DSP Router Settingfor it, but the other ones, they *SHOULD* Work with the other Audigy2 Cards.
GFORCE
Postby justchillinout on Mon Oct 17, 2005 1:43 pm
Aha, so there is still activity!
I'm using a SBLive! 5.1
There's a good chance the Audigy settings would work (I hope).
Any help is certainly appreciated.
Now all I'll have to do is find out why my motherboard just cratered! :(
justchillinout
Postby edgley on Thu Oct 27, 2005 10:54 pm
I have now given up on ANY product from Creative.
I would rather have Bush round for dinner than give them money again.
I would suggest saving up the bucks and going for a M-Audio card.
I have one on order and will report back when it is here.
edgley
Postby Colby on Thu Oct 27, 2005 11:16 pm
Edgley,
I would concur, Creative cards are the Devil. I bet you will never actually fully remove it from your HD, save formatting and flashing Bios. It lingers like a throbbing splinter painfully infecting all it touches. I prefer my onboard audio to SB 5.1 anyday.
