bleeding edge update touchscreen issue
Postby billberet on Thu May 13, 2010 2:48 am
ok here is a new one,
just did the bleeding edge update and i lost the ability to activate anything in the upper right hand corner of the touchscreen.
about 1 in square. if i go into music and click the album cover in upper right corner of category, the title changes showing that i touched the cover art, but no action will occur.
on main screen, if i click on the weather icon in the upper right corner, the weather does not rotate thru the locations.
same goes for movies when i click on a movie. media player, i cannot click on anything in upper right.
anyone ever have an issue like this. any button in the right corner does not perform it's action.
i will uninstall and reinstall, and if i still have issue, i will go back one previous version, everything works fine there.
it's like XL has a dead spot, that's all i can think of to describe it.
any ideas?
ps: it's not the touchscreen , all my screens are behaving the same. outside of XL, i can click the corner without issue.
Re: bleeding edge update touchscreen issue
Postby billberet on Thu May 13, 2010 2:56 am
downloaded full update from DL page v3.0.10099.73
all is fine with the world again, my bleeding edge download must have had an issue or something.
Postby Jay on Thu May 13, 2010 12:02 pm
No - there is a bug. I emailed Steven.
It showed up on my server and tablet. Clients with the April 9 release are fine, as you say.
Postby billberet on Thu May 13, 2010 2:52 pm
thanks for the feedback Jay.
I'll keep my eye open for and update fix.
Postby Jay on Thu May 13, 2010 4:11 pm
It's ready. You can now run slide shows on the server from a client with several new button commands. Look in the pictures event group.
