I have just finished re-building my PC, XP was getting a little bogged down with all the software that had been installed and un-installed over time.
Anyway, have copied back Xlobby and updated to latest forum version for good measure, but I cannot get navigation working now from Girder. I think I am just forgetting something simple as it has been a long time since I have had to set it up.
I have girder talking to zplayer directly and that is working fine. I am using the same GML save file as before and have enabled the 3 plugins, IRman, SendMessage and grider2xlobby.
Grider recognises the remote key press and the assosiated action is linked to the grider2xlobby plugin and the setting show xlobby:navigation.down but xlobby does nothing.
where should I now look to try to figure out what is going wrong?
