I'm revising a skin for Remote control use. I think I have a pretty good handle on the Navigation system. however, my one issue is this, and perhaps it's best addressed to Colby as his skin takes advantage of it:
I can get every button press to go where I want barring the "Movies" section.
Right now the default is that a button press up or down will scroll between pages. I would like to change this so Left and Right will instead scroll between pages (as is does with ColbySkin2)
My search buttons and the like are above my movie window. If I set the navigation override to go UP to my MENU button from the Movies window, it all LOOKS on in the Skin Menu (ie. hitting up from movies will highlight the Menu Button) But then in practice the "cursor" gets stuck paging. I can move down into the movie window with no issues.
Thoughts?
