by lar282 on Fri Jan 21, 2011 8:47 am
[quote="Marbles_00"]Okay, I found a wee bug in that update. The icon only seems to change if you restart xlobby, otherwise it will only show the recon or recoff image. Example, the recoff image is showing and a show has started recording. It will not change to the recon image unless I restart xlobby.[/quote]
Try this for me please
Edit the
Program Files (x86)\Team MediaPortal\MediaPortal TV Server\Xlobby.xml
and put the clients ip number in there.It supports 2 ip adresses
Mine looks like this.
<XLrecDatabase XLrecDatabase="c:\program files\xlobby\databases\recordedtv.xml" XL_ipnumber="192.168.0.9" XL_ipnumber2="192.168.0.10" />
I remember that I removed the feature that XL checks periodically the tvserver because it was hogging resources. With the above it will push messages instead.
let me know
