Display certain page of category
Postby Arthur on Sat Dec 30, 2006 3:32 pm
Hello,
I try to have 10 items of the same category on one page.
I want to show the first item of the category in one field and then in an other field the second item etc.
Reason is I want the main menu, which is a database to show as a diagonal.
How can I make the catagory start with showing item number 2 oif 3 of the database?
Arthur
Postby S Pittaway on Sat Dec 30, 2006 5:03 pm
i wrote a plugin a while ago called xJumpTo which lets you find a certian entry in a category, you might be able to use that -
http://www.xlobby.com/forum/viewtopic.p ... ht=xjumpto
Postby Arthur on Sat Dec 30, 2006 10:36 pm
Thanks for your reply. I downloaded your plugin and it shows in the plugin section. However, I do not know how to use it.
I added an extra item to the database called "menuitem", which are just numers 1 to 10. Th edatabase is called '"mainmenu"
Do i put something in the textfield like
xjumpto>find text exact:mainmenu>menuitem>1
and how do I get it to display a different parameter of this item (label)
Arthur
Postby S Pittaway on Sun Dec 31, 2006 10:35 am
sorry, i just reread you question and i dont think that plugin will help... all that it does is highlight a given item in a category...
If you do a search on "P3rv3rt B3ar" i think he had something which might help... its called pervtalk or somthing silly like that :)
i have never used it so i cant comment on what its like tho.
Postby joebob2006 on Mon Jan 01, 2007 12:22 am
ok, lemme see if i got what you want right:
you want two categorys on one screen, and when you select an item in one category, it shows details of that item or a specific piece of info for it in the second category.
if thats right then i got you.
in the first category there is a field labled detailscatetory or whatever, set that to the name of the second cateory, done.
if you want details on something more specific lemme know
joebob2006
Postby Arthur on Mon Jan 01, 2007 2:15 pm
Almost joebob,
I want something which can't be done.
Let's say I have a category containing 6 items. If I put it on a screen and give it 1 colum and 6 rows it shows all the items of the category.
Now I don't want to have all thos items straight underneath each other, but in a diagonal
_____1
____2
___3
__4
_5
6
So I thought, lets put 6 category fields on a page, each showing 1 colum and 1 row. I can put those wherever I want. But as you open the page, thay all show the first item of the category, so you get:
_____1
____1
___1
__1
_1
1
While experimentging I noticed that all category fields will show the same item (so if item 3 is selcted thay all show item 3).
So I can't use a category field, but maybe a text field which reeds from the catagory is a possibility
Arthur
Postby S Pittaway on Mon Jan 01, 2007 4:55 pm
like i said, "P3rv3rt B3ar" has a plugin to do this, i just have not (and probably wont) use it.
Postby P3rv3rt B3ar on Mon Jan 01, 2007 5:16 pm
Yeah, now that i finally figured out what u wanna do... Pittaway is right xPerT does it. Allthough if u wanna try, i would strongly suggest the original or 0.91 version cause later versions have currently probs with that particular functionality... sad thing is though those older versions respond rather slow :(
I will have eventually new, fast and working version out.
Postby Arthur on Mon Jan 01, 2007 6:08 pm
:D Thanks, I will let you know when it's ready :-)
Arthur
