Roscoe,
Check out the link below:
http://www.xlobby.com/forum/viewtopic.php?t=3450
That's where badubo explained to me how to do it.
My events/startup group has the following:
startup event
os execute GBPVR
os execute Samurize (for weather as I've had continuous problems with the weather plugins)
wait for 20 seconds (for GBPVR and Samurize to load)
os execute sendfocus.exe to xlobby
I wait for 20 seconds because I'm currently testing my setup on a PIII 733. A more powerful system would lessen the load time, so the wait could be less.
The sendfocus.exe is used because when GBPVR loads, it takes over focus, which you want to regain for remaining in xlobby.
I've also set up a button on the main page with the following event:
to PVR
os execute sendfocus.exe to GB-PVR
This will place GB-PVR as the main window when entered.
To regain focus to xlobby from GB-PVR I've added a custom task. This can be done from GB-PVR's config screen under the plugin tab. Again I run the sendfocus.exe and xlobby as the argument.
If I recall right, when utilizing a custom command, you close the config panel and reopen to the plugin tab, and check off the extra box under Menu and Plugin. This automatically sets up a button on the main menu for the custom task. Then I added a task.png to the skin/custom folder.
Hope this was helpful.
Marbles
