first off all milanp thank you!!
but you know the position of steven about skins like mine (MCE CLONE)=don't be posted in the site sorry
Author Message
3rdman Posted: Sat Apr 17, 2004 7:36 pm Post subject:
I agree wholeheartedly...Great skin and it really makes Xlobby easier to manipulate with just a remote.
I've had a small problem with your skin, though and its driving me crazy. First of all, I couldn't import your "movieviewer"...every time I tried it would stay stuck at Loading:Images. So, to get around this I imported everything EXCEPT the movieviewer and used the movieviewer from Jowaldo's skin, modified to match your background and it's GREAT! The Next problem I've come across is with the actual launching of the offline movie. After I hit "play", the Offline Movie dialog pops up as it should, However if I hit "continue" it does nothing. If I then hit "cancel" and then hit "play" again, THEN it launches.
Loading other skins eliminates the problem. Any help would be greatly appreciated. I really love this skin and I'd like it to be my default display. Thanks.
3rdman i've the same problem for opening the drive and launching the movie at the first time why?
i don't no maybe a bug with the program or the skin!??
your problem in the movie viewer is the stills!!
with the skin editor delete the text item using the stills and restart xlobby and try to see if working.
