Im new to this forum and have just decided to move away from MCE 2005 to Xlobby as it appears to be a more flexible option and hopefully better suited for my needs.
One of the main reasons I did this is because I wanted to use a Simpad (handheld windows CE PC) as a remote control "client" for my system.
I have read the tutorial on here about how to do this but do not seem to be having much joy, The problems Im having are,
1) I can not tell if I have managed to install ".NET Compact", I download it to my desktop pc and then run the program. The Active sync opens up and appears to load it to the Simpad however I can not find any record of it on the simpad after (ie in the program list or anywhere else)
2) This problem I feel may be caused by not having ".NET Compact" installed correctly - I copy the "xlobby2sd.exe" & the "servers.txt" (ammeding the varables to suit my IP address) to the simpad and try to run them but get a message saying the programs are not compattable with the machine.
Any help much appreciated
