Hi Guys,
I have decided to move away from a squeezebox and use a USB DAC in my 2 channel room. I am using a Xlobby layout that I have used for a while in my HT (Naylia's XlobbyMcSkin), the difference is I am using a newer version of FooBar 2000, version 0.9.5.1. I have the two plugins placed in the proper locations in the Foobar directory and I am using the newer Xlobby foobar plugin.
Foobar opens when I open Xlobby but when I try to play a song via Xlobby the choice never shows up in Foobar. If I play a song directly from Foobar it plays fine. Is there a new configuration required with this version of Foobar? All I have had to do to get Xlobby to play misic in the past is tell it here Foobar and the music database are and scan the database, viola, when I told xlobby to "Play Track" it did.
BTW, the revsiom of Xlobby I am using is: 1.0.1937.250.039,Xlobby 2.0
Ed
*edit*
Nevermind guys, upgrading the Xlobby to the latest freeware version has me running fine now.
Ed
