Hello everyone,
Newbie here who just started using Xlobby yesterday. What an incredible program. This is the first front end I have ever used so it will take me a little while to get things configured the way I want, but I am really looking forward to it.
Anyway, I have a small problem that I can't figure out. I record a lot of HDTV using WatchHDTV, (another great app.) and I use the WatchHDTV player that came with it to play back the files. For those of you not familiar with WatchHDTV player, upon startup it reads a small text file called decoders.txt to let it know what decoders the user wants it to use. Without the decoders.txt, the player will automatically go to it's default decoders (Cyberlink ATI decoders in my case). My decoders.txt file is set up so that the player uses Cyberlink for video and the AC3 filter for audio.
The problem I am having is that I can't get the WatchHDTV player to read the decoders.txt file before startup when I launch it through Xlobby.
Here is how I set it up in Xlobby after I pressed F2.
Went to databases, selected movies and added dvr-ms to file types.
Imported the dvr-ms files to the movie database.
Under file types, I added the path to the WatchHDTV player and put dvr-ms in the extension section and put %parameter% in the command line switch (FYI-I have no idea what the %parameter% means yet, just did that after reading posts here) and then I enabled it.
Then I closed out setup, went to movies and selected one of the files to playback. It launches the WatchHDTV player and the show starts. Everything is great except the audio being sent to my receiver via SPDIF is not in dolby digital, meaning the player isn't reading the decoders.txt before launching. If I launch the player outside of Xlobby, it works with the proper decoders.
Does anyone have any idea on how to get the player to read the decoders.txt file first?
Sorry if this is confusing. I appreciate any help or advice.
BTW-If I set TheaterTek up to play the files back, it also doesn't send the dolby digital signal to my receiver and uses about 80% of my CPU while WatchHDTV uses about 33%.
Paul
