- Cropped and sized to it bounding box
- alpha channel is preserved
- if you've named your elements or groups, the element's name is used as the filename
- Only visible elements are exported, hidden and web layers are skipped
Installation:
- Copy and paste the code below to Notepad or other text editor
- Click File > Save As..
- Enter a descriptive name such as Export all Elements to PNG.jsf
It's important to note the .jsf extension, you can name the file anything you like but the extension must be .jsf - Navigate to the Configuration\Commands folder under Fireworks installation folder, usually C:\Program Files\Macromedia\Fireworks 8\
- Create a new folder under Commands named Export
- Save the file to the newly created Export Folder
C:\Program Files\Macromedia\Fireworks 8\Configuration\Commands\Export\Export Elements to PNG.jsf
To Use the Command
You will now have a new command group available Menu > Commands > Export. There is a menu entry with the same name as the filename you entered earlier, Export Elements to PNG
- Select this new command to start the export of your layout.
- A dialog box will appear. Select the destination folder for your individually exported files to be saved.
- In the filename field enter a name that will be used as the filename prefix for any element that you did not name in the layers. An example would be SkinPart . Any unnamed elements will be saved as SkinPart 1.png, SkinPart2.png, etc.
- Click Save
That's it! Now each piece of your layout is ready to be used as buttons or layout elements in xLobby.
- Code: Select all
function exportAllElementsToPNG(){
var dom = fw.getDocumentDOM();
var filepath = fw.browseForFileURL("save");
if (filepath == null) return false;
var defaultname = Files.getFilename(filepath);
filepath = Files.getDirectory(filepath);
var elems = new Array().concat(fw.selection);
dom.selectNone();
dom.setDocumentCanvasColor("#ffffff00");
var sXO = dom.exportOptions;
var oldcrop = sXO.crop;
sXO.crop = true;
sXO.ditherMode="none";
sXO.ditherPercent=100;
sXO.exportFormat="PNG";
sXO.colorMode = "32 bit";
sXO.optimized = true;
sXO.paletteTransparencyType="rgba";
var f = dom.currentFrameNum;
var n = dom.layers.length;
var i, j, m, elem;
var visArr = new Array();
for (i=0; i<n; i++){
if (dom.layers[i].layerType == "web" || dom.layers[i].frames[f].visible == false) continue;
m = dom.layers[i].frames[f].elements.length;
for (j=0; j<m; j++){
elem = dom.layers[i].frames[f].elements[j];
if (elem.visible) {
elem.visible = false;
visArr.push(elem);
}else{
visArr["_"+i+"_"+j] = true;
var rect, name, filename, counter = 1;
if (visArr["_"+i+"_"+j]) continue;
rect = elem.pixelRect;
elem.visible = true;
name = elem.name;
if (name == null) name = defaultname + counter++;
filename = filepath + "/" + name + ".png";
sXO.cropLeft = rect.left;
sXO.cropRight = rect.right;
sXO.cropTop = rect.top;
sXO.cropBottom = rect.bottom;
fw.exportDocumentAs(dom, filename, sXO);
i = visArr.length;
while (i--) visArr[i].visible = true;
sXO.crop = oldcrop;
dom.lastExportDirectory = filepath;
fw.selection = elems;
return true;
exportAllElementsToPNG();
