Thanks for replying!
Here's the info to your q's
System trying to use are atari (for now, just atari as an example)
file types = .bin
file struct for roms = c:\x\atari\roms
emulator = stella
no coverart at this time
I played with trying to make a database last night, and I was able to see it on my atari page successfully. However, when restarting xlobby, it seems to freeze when trying to load "LOADING: SCREENS."
Here is my procedure on what I did...and the errors I recieved alon the way...
1. Loaded xlobby with colbyskin
2. Ran Setup (F2)
3. Created Database by using the import tab, selecting the "roms template," my extensions as .bin, named the new database as atarirom, added the path to look for the .bin files, and then imported. The import completed sucessfully.
4. After the successfull creation of the database for the roms, I opened the skin editor.
5. I went to the "goto screen" and selected the "atari screen."
6. I then selected the "screen" tab on the editor.
7. Now this is where I get problems...and some misunderstanding. To my belief, I need to create a catagory to house my database, so the atari page knows what catagory to look for. So I go the the "Add Catagory" sub-tab on my "screen" main tab, and I type in a category, and then click "create custom category" (I call it "atarirom).
8. Sometimes, and not all the time -- I can then goto the Edit Category screen and my category will be there, and I can choos my database for my screen. Other times, It says "no category selected." How do I officially select a category? Where do I choose it?
9. Then, if I am able to edit the category, I can visually see the thumbnails for my roms on my atari page. And they work sucessfully on loading the games!!!!!!!! Great!!!!!
10. However, when closing the editor I recieve this message:
- Code: Select all
"A unhandled exception has occured in your application."
Details:
System.NullReferenceException: Object reference not set to an instance of an object.
at xlobby2.FormSkin.toXML()
at xlobby2.GdiForm.unpause()
at xlobby2.SkinEditor.CloseEditor()
at xlobby2.SkinEditor.closing(Object sender, CancelEventArgs e)
at System.Windows.Forms.Form.OnClosing(CancelEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
xlobby2
Assembly Version: 1.0.1580.32678
Win32 Version: 1.0.1580.32678
CodeBase: file:///C:/Documents%20and%20Settings/richk/Desktop/x/xlobby/xlobby2.exe
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
XPluginSDK
Assembly Version: 1.0.1580.30012
Win32 Version: 1.0.1580.30012
CodeBase: file:///C:/Documents%20and%20Settings/richk/Desktop/x/xlobby/XPluginSDK.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Documents%20and%20Settings/richk/Desktop/x/xlobby/AxInterop.SHDocVw.DLL
XWeather
Assembly Version: 1.0.1577.33604
Win32 Version: 1.0.1577.33604
CodeBase: file:///c:/documents%20and%20settings/richk/desktop/x/xlobby/plugins/xweather/xweather.dll
Interop.SHDocVw
CodeBase: file:///C:/Documents%20and%20Settings/richk/Desktop/x/xlobby/Interop.SHDocVw.DLL
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
enabled.
For example:
<configuration>
</configuration>
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Lastly, when trying to restart xlobby, I freezes on the "LOADING: SCREENS"
Since this is still in alpha (I guess) is this common to happen? Am I creating categories incorectly, or does creating categories in this alpha version still too buggy?
Any help would be appreciated, but it is not life or death. Trying to discover if xlobby would make a convient application for my archade/gamming console.
Thanks!
