I have been wondering this for a while. Can Girder control Xlobby? I would love to have homeseer control girder which in turn would control Xlobby
Tim
jmb295 wrote:Badubu,
I was attempting to use your plugin to control xlobby through girder, but xlobby was unable to receive any of the commands. I was able to import all of the skin events, and select match them up with seperate girder commands. I just send a keyboard event to the foreground task, then the commands work. But when I select the xlobby plugin I don't see anything happen in xlobby. Any ideas on things I can look into, I'm fairly familiar with girder.
Thanks!
[/quote]badubo wrote:It seems that the link I give above was not updated
can you test with the last version?
same link
http://www.france.xlobby.com/plugins/gi ... 040730.zip
