How well does Dell Axim X51v work with Xlobby?
Postby redondo_se on Fri Jul 07, 2006 1:55 am
Hi all,
To dalanik or any other X51v users, how well does it work with Xlobby? Does it have the issues that some PDAs have with the wireless disconnecting after a period of innactivity requiring a reset? How responsive is it?
redondo_se
Re: How well does Dell Axim X51v work with Xlobby?
Postby dalanik on Fri Jul 07, 2006 9:00 am
I have powersaver disabled for WiFi card, so it doen't... As far responsiveness is concerned, it is a bit slow for my taste, but I only have ad-hoc WiFi - Axim is connecting to PC with WiFi card, and that PC is on the LAN via cable... We'll see when I get a proper WiFi access point... :-)
And if it hangs, I can always close the XLobby client with switcher bar and start it again... no reset necessary.
D.
Postby dvard on Fri Jul 07, 2006 11:57 am
I use an X50V and an X51V from time to time and I think that they
work well with Xlobby. I don't use them alot, but they do come in
handy. I use a wrt-54gl router in infrastructure mode.
Don
dvard
Postby redondo_se on Fri Jul 07, 2006 9:09 pm
Thanks for the feedback guys. Just trying to plan my future house. I will probably give one of these a try.
redondo_se
