How to list recorded shows as made ??
Postby r45t4m4n on Fri Jul 09, 2004 7:42 am
Is there a way to have xlobby scan a specified folder and list all the videos in it? I would like to set my dvb program to record to a common folder and in xlobby have the videos show up in the recorded shows section I made. I tried doing it but only the first file of each folder is played. I have a tvrecord database setup at the moment but I have to add each show manually.
r45t4m4n
Postby Hiller on Fri Jul 09, 2004 12:37 pm
I'm pretty sure Chad's old skin did something like this. It just had basically a file list of the stuff in a folder that you could select. I'll have to look once I get home and I'll let you know what I find.
Steve
Hiller
Postby r45t4m4n on Fri Jul 09, 2004 3:42 pm
awesome, thanks
r45t4m4n
Postby stevenhanna6 on Sat Jul 10, 2004 2:26 am
If you set the import type to "custom" then set it to folder "container" it should import everything in that folder.
Postby jsilva on Sat Jul 10, 2004 10:39 am
Can you refresh it I mean if I delete a file and if I refresh the database will it show?
jsilva
Postby stevenhanna6 on Sat Jul 10, 2004 4:08 pm
yah if you refresh it the file you deleted should be gone.
Postby r45t4m4n on Sun Jul 11, 2004 4:12 am
when I try to add a path in the import menu after setting custom and container I get an error that asks if I want to continue, exit or details. When I choose continue the path is not added.
r45t4m4n
