by hjackson on Sat Jun 25, 2005 1:31 pm
It will have to be at least USB 2 (not USB 1) for DVD. The drive will need to be formatted in NTFS, not FAT, to accomodate large file transfers. The drive letters should not change unless you are rearranging the external drives after setting them up. You will access the drives' folders the same way you would any file on your PC.
Good luck.
hjackson
