Hi All,
I Just made available this TV plugin for tuner cards with integrated hardware encoder chips. The core of this plugin is based on CTpvr. This plugin require CTpvr be installed for it to Timeshift Live TV. For now it has some basic PVR fuctions included. You can watch Live-TV, Pause Live TV and Playback video files. I will be adding EPG support soon.
I've made a generic screen(see below) that XCTpvr will copy over to whatever skin you may be using. Even if you change to a different skin, it will copy it to that skin. You only need to add one button to the Xlobby main menu to goto to the XCTpvr screen. Then assign the event under skins->XCTpvr->goto XCTpvr and you are ready to go.
http://ctpvr.com/downloads/XCTpvr.msi
The installer has a default install directory of "c:\program files\xlobby". Some of you will need to change this to where ever Xlobby is installed.
Known Bugs:
Timeshifting may not initialize when you press the pause button.
Switching between large and normal view may hide video window.
Regards,
Carm.
