Anyone doing this: XLobby - PVR - DVB ???
Postby Aaron on Sat May 08, 2004 6:21 pm
I'm hoping there is some experience here with building an HTPC that will run two DVB (Nexus-S or the like), XLobby, and PVR (any).
My goal it to create a PVR simular to a dual tuner tivo.
Anyone do this and can give info it is greatly appreciated.
Aaron
Postby Aaron on Tue May 11, 2004 1:51 am
37 views but no replys :cry:
Aaron
Postby jowaldo on Tue May 11, 2004 4:58 am
I'm not sure if anyone has been successful at a setup like this yet... probably why nobody has responded
Postby jsilva on Tue May 11, 2004 7:54 am
I use ritzdvb for my two cards a dvb s and a dvbc and launch it from xllobby it's not ideal but it works fearly well
jsilva
Postby lar282 on Tue May 11, 2004 8:34 am
what about using dscaler and progdvb. Wouldn't that work?
I only got one card and using dscaler and that works really good.
OOPS... Double postings
Postby ippo on Thu May 13, 2004 8:02 pm
ippo
Dscaler
This is exactly what i'm trying to do right now... with no luck whatsoever...
I have a dvb-t card and have set it up with progdvb and windtv (the software that came with the card) nd this part works well.
But I'd like to get the EPG part to work aswell....have tried myhtpc (thought it might work to have myhtpc as a front end only for epg and use it to schedule and launch live tv...) but no luck the only thing that I have success with is to show the EPG in both Xlobby and MyHtpc but no more... *argh* :twisted:
ippo
