Xmedia2 by sagitaz www
Postby Chazotta on Wed Jul 06, 2005 10:47 am
I replaced those 3 files with the ones in the Xmedia2 skin directory, but I still have the same (or similar) problem.
I am using the latest xlobby2.exe. Would this matter ?
Chazotta
Postby dgemily on Wed Jul 06, 2005 11:35 am
This is very strange, the organisation of categories is saved in the xml files, but when you use them on your configuration, the organisation changes…. :shock:
Can you send me your xlm files ( just these 3 xml), just to look if xml files are changed after you start xlobby and to see what is changed…..
Did you try with 800*600 ?
dgemily
Postby sagitaz on Mon Oct 24, 2005 11:06 pm
sagitaz
Postby sagitaz on Wed Jan 11, 2006 1:37 am
new update :
you need the new XVis plugin for visual.
player audio access from all not videos screen :
overlay-player access from videos screen :
sagitaz
Previous
