Is it possible, and if so, how is it done to include Winamp's balance control and Crossfade timing parameters in with the EQ controls (using Winamp 5.08 )? If so, what is the ID tag to use? I've tried a couple of straightforward ones (balanceleft, crossfadedown) but they are not correct.
Colby, any chance you could add further EQ information into your great Events Variable document? It has EQ (band information) and EQ toggle, but I didn't notice anything that states the variables to enter in the ID tag under the Default tab of the skin editor.
