Deleting files
Deleting files
Postby chaumurky on Thu Aug 03, 2006 9:10 am
Quite a simple one really. How do I make a button delete a selected file in a database and have the database automatically update to reflect the change?
chaumurky
Postby stevenhanna6 on Fri Aug 04, 2006 4:59 am
use the
os->delete
command, be VERY carefule with it...it will delete the file that is in the "parameter" field. Maybe you wanted the specify another field?
AGAIN BE CAREFUL WITH THIS COMMAND, I use an overlay when I do it...saying "don you wish to delete"
