cmhardwick wrote:I have mine do the "reset" as part of the close event for my TT control screen. Have you tried that?
How do you do that ? Some pics if possible ?
Thx.
cmhardwick wrote:it's just part of the event that is executed when I click the close button on my TT control page. The last command is exactly like the execute event to copy the cover art over, but it copies the DVD logo you created instead.
cmhardwick wrote:you would need to use the EXIT event, which should work. Not sure why it wouldn't. It is set, in the skin editor, by of course going to the particular screen you want to edit, then click on the SCREEN TAB at the top, then the EDIT TAB. Enter and Exit events for the SCREEN are there. The "enter/click/exit" events you may have looked at were for the individual buttons, NOT the screen.
PiDD wrote:Is this plugin still around? Sounds very cool! pls email it to pidd'at'shaw'dot'ca is its available.
I had a pc camera setup on my center channel and it would shoot a pic before the movie and put it up on the screen. kinda cool but got old.
gravy wrote:Thanks for this. It would be so great if we could specify some type of text to accompany the image, like:
"Take your seats, your feature is about to begin!"
Better yet would be if we could specify the text as an xlobby parameter in the plugin..
thekochs wrote:gravy wrote:Thanks for this. It would be so great if we could specify some type of text to accompany the image, like:
Agreed....but you just need to create the jpeg image you want....you can use a variety of software packages to create such an item. You can also web search for alot of good backgrounds to start with and overlay some text in the most simple of programs.....Paint.
