I am using Winamp5 and have set it up in the file types. I am a little confused on the start event option in file types and how it ties into everything. At first, I thought that start event had to match the event associated with the play button. But, I noticed with my movies this isn't the case. ZP is set up in file types with the start event as movies:load playlist and the play button's event is pointing to movies:play movie which goes to execute:movies.
I tried the same with music, setting the play button's event to music:play --> execute:music. This does start winamp but the tracklisting is not in the correct order.
I think I am missing something obvious as I've been able to create my own skins and set up every other aspect of xlobby to run perfectly
Thanks in advance for any help!
