I created a database with the parameter :
<parameter>SCREENNAME<parameter>
I assigned to the category an event goto screen with "Screen Name" :
%CATEGORYNAME>parameter%
but it's not working
Please, Does anyone have a solution ???
Thanks.
Dgemily, can you confirm that you can direct the menu category to individual screens? Thanks.
maybe the next logical step is to have the ability to give database objects an event....so depending on which you click it will have a different effect....just an idea. I'll do it if you guys think it would be good.
stevenhanna6 wrote:ready for testing
when you edit a database now you will see a new tab called "advanced" this is where you will set your event. Post your results...I have not tested it much.
