NOT USED OLDMediaPortal (Tv Plugin) special build for xlobby
Postby lar282 on Sun Aug 07, 2005 10:39 am
GFORCE wrote:Im Having Jitter/Frame Dropping problems on HDTV Channels.
Ive got a Skin Problem, the Close TV Button gets overlayed with the Teletex Button when the TV is on.
jitter u have to ask the MP forum....
for the overlay prob, open the mytvhome.xml and move the button down alittle. I dont have teletext so I didn't see this..
So u got the dvb-t card to work? what was wrong?
Postby GFORCE on Sun Aug 07, 2005 12:48 pm
codec's, i wish they implement vmr7
GFORCE
Postby lar282 on Sun Aug 07, 2005 1:45 pm
why, isn't 9 better?
What codeocs do u use?
I use overlay myself cause it gives the best picture on my projector. I do miss the flickerfree osd when using overlay.
Postby GFORCE on Mon Aug 08, 2005 8:31 am
ive got a problem but im not sure what it actually is,
The top of the screen gets Vertical sync lines across the screen like VSync is off. but ive got it on.
I might need to Install the Latest Drivers.
GFORCE
Postby GFORCE on Mon Aug 29, 2005 3:18 pm
i hope you can compile a new version of MP since they have new CVS that can do Direct TS Dump, no more .ms-dvr
GFORCE
Postby lar282 on Mon Aug 29, 2005 4:49 pm
I promise to do that for u if u explain what it is?
Is it just for dvb cards or can we analog users also use it?
Is it mpg direct or what? I know to little about it.
Isn't it better to wait to compile until next big release?They have a tendensy to add bugs in cvs and clean up at the end...up to u, but all works for me now so I'll keep me build but of course I'll compile for u if u want.
Postby GFORCE on Tue Aug 30, 2005 5:21 am
TS DUmp,
it records in pure DVB SDTV/HDTV Support
it dumps the decoder from the dvb tuner directly to the hard disk
GFORCE
Postby lar282 on Tue Aug 30, 2005 6:24 am
Ok, so analog users do not benefit from it.Thats why I didn't see it!
Do u have any means of trying the build. I did it last night. U got a ftp server or something?Dont think I should any more space from Steven!, and I don't wanna remove the current one until we know the new one works.
u can mail me at
mailto:lasse10@telia.com
Postby lar282 on Wed Aug 31, 2005 7:48 am
GEForce I updated the installed with the latest cvs files. See the first post for changes.
the commands in xlobby changed.removed unneeded once.
Postby GFORCE on Tue Sep 13, 2005 2:12 pm
hey lar282,
is it possible to have a button that displays if MP is recording or not?
Status is good, but the recording will be good.
GFORCE
Postby lar282 on Tue Sep 13, 2005 2:15 pm
don't know if its possible. I can take alook at it this weekend. for me its always recordning if the status is ON so its the same. thats because I shut it down when it is not gonna record or recordning.
How do u use MP? U saw the new option in the xml file to let MP shutdown instead of Minimizing?
Postby GFORCE on Tue Sep 13, 2005 2:19 pm
I always have MediaPortal minimised to the tray
i have a button that shows MediaPortal and i press 'Close TV' to return to MediaPortal
GFORCE
Postby lar282 on Tue Sep 13, 2005 2:21 pm
I guess you want it to minimize. Thats ok. I'll check the record status this weekend
Postby GFORCE on Tue Sep 13, 2005 2:28 pm
thank you
GFORCE
Postby lar282 on Thu Sep 22, 2005 7:15 am
GFORCE wrote:hey lar282,
Sorry but I couldn't do it. It is beyond my programming skills. I just could make the one dll talk to the other.
