Add to top of Queue, Play Next
Postby escort on Sun Apr 30, 2006 8:27 pm
Here is what I am tyring to do. I want to be able to add a song to the top of the queue after I do a play all and then hit shuffle. If I select a new song to add, it simply puts it into the shuffle queue and not next. I want to add it to the top to play next. Any ideas? thanks
escort
Re: Add to top of Queue, Play Next
Postby dalanik on Sun Apr 30, 2006 9:37 pm
escort wrote:Here is what I am tyring to do. I want to be able to add a song to the top of the queue after I do a play all and then hit shuffle. If I select a new song to add, it simply puts it into the shuffle queue and not next. I want to add it to the top to play next. Any ideas? thanks
Sorry, but if you have shuffle (random) that means that you want to play songs in ramndom order, why would added tracks be put next??
If you don't have shuffle on, you can just add it normaly, and then in playlist (depending on the skin) move that track manualy to the desired positiion...
D.
Postby Colby on Sun Apr 30, 2006 10:25 pm
heres an idea,
save the random shuffled playlist, then select your song, then add the playlist back. Maybe one event could do this behind the scenes?
Postby escort on Sun Apr 30, 2006 11:06 pm
Colby that is a good idea. I am attempting to make this easy enough to have my dad use it. With the current jukebox he uses he can go up to it touch play all and then hit the shuffle key. Anyone can come up right after him and select a song and it will play after the current song is done.. It does not bump it. Will this be somthing that needs to be coded in the source or is there some I can try?
escort
Postby dickiedoo on Sun Aug 03, 2008 4:53 am
I also Play all, then shuffle. I want to queue a specific song to play after current song.I'm real green...so if anyone has any ideas on how to accompish this with winamp I would appreciate it.
Xlobby has changed my life.
dickiedoo
