Only some of the music I listen too can be found at Amazon. About 50% is not there. Is there a particular size that I need for the cover art to show up or any pic will do ?
Stuart
stevenhanna6 wrote:stuartambient, are you using the latest EXP7 version?
As an example when I went into the database to spider for covers, I noticed that a whole bunch of albums had no names, only the little plus sign to see inside the directory.
stevenhanna6 wrote:you need something like tag and rename to fix your tags up
http://www.softpointer.com/tr.htm
