Skins......
Skins......
Postby Camisano on Fri Nov 05, 2004 8:46 pm
I now have music playing thanks to BADUBO. I also downloaded the Colby skin and the Visual skin and thanks to BADUBO I know how to activate them, the only thing is I cannot get in to the help / set up section of Xlobby through either of these. Does anyone know if they are suppossed to be like this or is there something else I need to do.....Thank you
Chris Amisano
Camisano
Postby mattdisaster on Fri Nov 05, 2004 9:27 pm
F1 should work to get to the help screen, that is if the creater left one present. And F2 should bring up the setup screen. If these dont work then something is wrong, keep us posted and good luck!
-matt
mattdisaster
