Hi Jowaldo,
Thanks for taking the time to help.
I have downloaded and installed Cdex in the installers default place.
Do I need to install it in the plugins folder?
Under f2>plugins, there is no mention of it.
s.
edgley wrote:thanks
Sorry to bother again, but...
When I try to query for track listing, I get an error saying invalide email address, even though when I go into the programme it is okay, and the track listing is present.
I did try adding my email address as a variable under the CDDB command but with no luck.
Any ideas please?
jowaldo wrote:Edit - here is an updated link to my skin that is made to work with the resource manager
http://members.cox.net/xlobby/jowaldo-beta3test.zip
Well its been quite a while since I posted the first copy of my skin. I haven't had near as much time to work on it as I thought I would, but I finally feel comfortable posting the newer version of it.
The main thing I was unhappy about with the first beta was that all the text buttons had the text embedded into the image. Now with the new outline feature (as you can see I use a lot) for text, now no buttons have text embedded on them, but I kept the same look as before. Even the orange buttons on the main screen don't have the little icons on the left of them attached. They just are basically sitting on top of the buttons.
Also I had quite a few images for backgrounds, but that left very little flexibility in the skin. So now with the non-rounded egde (or "normal rectangles") none of the screens have images for the backgrounds. They are all made of resizeable shapes so its super easy to customize. Even the popup overlays are 100% made of shapes.
I also made quite a few new buttons... too many to list.
Most of the ppc screens are pretty much finished. There are a few little tweaks still needed for some of them.
A new big section is the "control" pages, for controlling devices with the usb-uirt, or girder, or whatever you want. There are also similar pages for the ppc. Just click on the remote icon at the bottom of the main screen to get to them.
Autoplay screens are also included for cd and dvd, but you will need to go into the setup screen and associate the pages with the autoplay event.
The weather screen have been updated to use the new weather plugin, and the images for it need to be downloaded separately and unzipped to the /plugins/xweather/images folder. You can download the ones I use here if you want:
http://www.deviantart.com/deviation/5215175/
I made a real basic games screen and a waaaay more basic music videos screen, which is still kind of a work in progress.
Oh and for 16x9 users this skin may take a bit of tweaking since I haven't tested it much for those resolutions. For the next beta hopefully I will fix all the tags on the background shapes so they strech accordingly.
I'm sure I forgot to mention a few other things, but here it is, please let me know of any bugs or things I could do to improve it, or just anything you like about it.
http://members.cox.net/xlobby/jowaldobeta2.zip
Also please post any requests you may still have[/b]
samsonlov wrote:Hey Carlos,
You are replying to a post that was made by Jowaldo 5 1/2 years ago.
according to his profile, the last time he was "logged-in" where he allowed the system to see him was in April of this year. (about 4 months ago)
To answer your question:
What you want to do is change the category event to be the same as the event that is assigned to the "play" button on the "preview" screen.
I don't have the skin, and I haven't used freelobby for a number of years, but if you open the skin-editor and go to the "preview" screen and take a look at the event tied to the play button, and then make that event your category event, that should solve your problem - though you might also have to change the properties of the category so that clicking doesn't display the "info screen" which in this case is called "movieviewer" - look in the properties of the movies category and where you see "movieviewer" just delete it.
(Make a backup of your entire xlobby folder before you try any of this, so that it will be super easy and fast to go back to a "working" copy of your xlobby setup.)
I hope this helps,
