XNowPlaying.v1.2.exe
auto-installer.
there are an exemple skin.
you need open the config.ini and change database path. this tool requiert plugin Xevent. change the XalarmPath.
Run exe for create the database and run xlobby on XNowPlaying skin.
[img]http://www.france.xlobby.com/forum/sagi ... g%20(Small).jpg[/img]
[img]http://www.france.xlobby.com/forum/sagi ... l%20(Small).jpg[/img]
