Client question
Client question
Postby stuartambient on Tue Jul 06, 2004 11:09 am
Does the client code require RPC's or open sockets to connect to the server?
The reason I ask is my client dies before starting.
I installed some software a while back that closes down raw sockets so wondering if that is the problem .
Stuart
stuartambient
Postby Cosworth on Tue Jul 06, 2004 12:28 pm
You might want to check if your server is set to "server" in the general settings (F2).
Cosworth
Postby stuartambient on Tue Jul 06, 2004 12:33 pm
Cosworth wrote:You might want to check if your server is set to "server" in the general settings (F2).
It is.
Stuart
stuartambient
Postby stuartambient on Sun Jul 11, 2004 1:54 pm
Well I confirmed that closing down raw sockets does effect the client.
I suppose I could have did more work then uninstall the socket locks and just punched a hole somewhere for xLobby to connect but alas it's all too confusing to me.
http://www.grc.com/dos/sockettome1.htm is the page that talks about XP raw sockets and their inherent dangers when opened. Now I will say one thing. Sage never had an issue with sockets being closed. So perhaps in the future we can find a better way for the client to connect to the server.
Stuart
stuartambient
