Thanks guys for helping me with the music database and cover art import - everything works fine, except that now when I close Xlobby and try to run it again it will not load properly. It stops when trying to load the (music) database. The only way I can get Xlobby to run is to remove the music database file from the database directory in Xlobby and then I have to re-set the music path and import the files and the cycle continues.....
Can you help me out?
cheers
Mark
