xltv.dll problem?
xltv.dll problem?
Postby Newintown on Tue Jan 03, 2006 3:40 am
I have been using xlobby for a while now with great results.
I recently decided to play around with XLTV. I'm sure I installed it correctly, but xlobby will not load with xltv installed. I get the splash screen, and it goes through the loading of the various sections, however when it should launch the lobby screen, it drops me back to XP.
If I rename xltv.dll to xltv.dll.bak, then it finishes loading, and launches normally.
Is there a log file that I might be able to look at to see why xltv.dll is causing this problem?
Newintown
Postby badubo on Tue Jan 03, 2006 9:06 am
XLTV requires the last version of xlobby2
download http://www.xlobby.com/xlobby2.zip
badubo
Postby Newintown on Sun Jan 08, 2006 9:41 pm
Thanks!
That did it.
Don't know how I could have missed that.
Newintown
