Web server failed?
Web server failed?
Postby galileo2000 on Tue Feb 14, 2006 3:40 pm
I've changed my router and now when I try to run Web Server I am getting "Web server failed!" !!!!
WTF?
galileo2000
Postby sharp_1 on Tue Feb 14, 2006 3:42 pm
I have the same problem.
Have checked your router to make sure port 8002 is open?
sharp_1
Postby galileo2000 on Tue Feb 14, 2006 5:47 pm
Yes, I did.
Actually "main" HTPC runs fine. I've assigned low port. It is my laptop with high port that fails. Might be a router issue. And yes, all ports are forwarded correctly.
galileo2000
Postby galileo2000 on Wed Feb 15, 2006 1:28 am
Changed to low port (<1000) and now it works fine...
galileo2000
Postby sharp_1 on Wed Feb 15, 2006 3:30 pm
I am having a problem trying to get my windows ME to act as a server. I have an XP laptop that I want to use as a client. I can get my XP laptop to act as the server and but not the ME desktop. Hmmm!! I keep getting an error message in the "who's on the network" window. Ugh!!!
sharp_1
Postby sharp_1 on Thu Feb 16, 2006 9:16 pm
galileo2000 wrote:Changed to low port (<1000) and now it works fine...
How did you set the lower port number...it doesn't seem to be an option???
sharp_1
Postby stevenhanna6 on Fri Feb 17, 2006 2:06 am
sharp_1, they are talking about the webserver, not xnet. I replied to your other thread if you want help with that.
