I have set-up Xant and AMC on my Xlobby server and my movie database has been imported successfuly.
I have 3 questions on implementation on fat clients:
Graphics
I have the graphics embeded in the amc database (and have also exported them to a folder)
The server can see the graphics perfectly, but the client cannot.
The client looks for the images using the 'images' entry in Xant.ini, but this is pointing to a drive on the wrong machine.
I have tried creating a share and then using unc names in Xant.ini (images=\\server\Catalogs\Movies\), but if I do this the Xant plugin will not run.
A possibility is to copy the images folder to the same location on each client, but this is messy and needs updating manually on each machine everytime a new film is added
How can I get fat clients to see the movie covers, so that the covers are automatically updated?
Using Daemon to mount image files
The standard moviestemplate.xml uses the parameter
<parameter>"%$$ITEM_TYPE $$ITEM_MEDIA" "$$ITEM_URL"</parameter>
If I use this and add OMP to Events (pointing at zplayer.exe) then when I hit play, I get asked for the DVD and Daemon does not mount the iso.
I can bypass OMP by removing it from events and changing the parameter entry to <parameter>$$ITEM_URL</parameter> which allows Daemon and Zoom Player to work normally.
I would like to understand
What is the purpose of using the the default parameter setting and OMP?
How do I set up OMP to work with Daemon?
Thank you,
Martin
