PhilB wrote:I leave the overlay up for 20 seconds so if it pops two at the same time I dont notice. It does not pop 1 for 20secs then another for 20secs. I am sure of that.
"Who Cares".....u must be in marketing:)
PB
Can u post your log here, cause I do not see your behaviour regarding 2 calls. Sure u do not have 2 modems installed or regged in the xml file?
Mine looks like this
2006-11-30 21:36:58 OnCallStateChanged() was envoked. call.CallState=Offering
2006-11-30 21:36:58 Ring Ring.Phone is Ringing, nr#rings=1
2006-11-30 21:36:58 OnCallInfoChanged() was envoked WITH CallerIDxxxx
2006-11-30 21:36:58 Phone Event:CID:xxxxx
2006-11-30 21:36:58 GUI_MSG_Incoming_Call_With_CID:xxxx
2006-11-30 21:36:58 forcing the 120 sek rule to go away.line 692 in callerid.cs
2006-11-30 21:36:58 Incoming_Phone_Call got envoked. Parameter sent:xxxx
2006-11-30 21:36:58 Zoom:False MP:False
2006-11-30 21:36:58 bailed on yac special when it already contains name and number
2006-11-30 21:36:58 Trying to find the record of the caller:xxxx
2006-11-30 21:36:58 Didn't find a image for then caller, using unknown.jpg:::c:\program files\xlobby\plugins\xcallerid\database\unknown.jpg
2006-11-30 21:36:58 Found a directory for the caller.
2006-11-30 21:36:58 Reading txt file for the caller
2006-11-30 21:36:58 Sending a YAC message. Name=Lasses Jobb number=xxxx
2006-11-30 21:36:58 Sending a Xap message. Name=Lasses Jobb number=xxxx
2006-11-30 21:36:58 Writing Call log for the current caller
2006-11-30 21:36:59 Found c:\program files\xlobby\plugins\Xcallerid\incoming.vbs Running it
2006-11-30 21:36:59 Running TASKBAR notification program to show callerID
2006-11-30 21:36:59 With Parameters
2006-11-30 21:36:59 "Lasses Jobb" "xxxx" 8 "c:\program files\xlobby\plugins\xcallerid\database\unknown.jpg"
2006-11-30 21:36:59 OnCallInfoChanged() was envoked
2006-11-30 21:37::04 Ring Ring.Phone is Ringing, nr#rings=666
2006-11-30 21:37::07 ncdTicks >=autoclose && autocdenabled IS True. gonna run Abort_and_Restore() if autoclose=true::::8
2006-11-30 21:37::07 Found c:\program files\xlobby\plugins\Xcallerid\resume.vbs Running it
2006-11-30 21:37::16 OnCallStateChanged() was envoked. call.CallState=Idle
