Hi All!
I have been playing with Xlobby for about a month now. I have a MyHD, and have downloaded the Art III skin and the MyHD plugin. I have Xlobby working pretty good so far, but certainly have a way to go. I plan on using the HTPC in a dedicated Home Theatre, so about 90% of the time It will be used for HDTV and DVD's. My question is, because the MyHD comes with a remote that will do a good share of the stuff I want, can I get it to work as the remote for Xlobby? What will I need? The Xremote plugin? girder? USB-UIRT?
 by keithf on Mon Apr 24, 2006 9:14 pm
by keithf on Mon Apr 24, 2006 9:14 pm  , so you shouldn't really need USB-UIRT. Find girder 3.29 (which is free) and test it with MyHD receiver and remote first, if it works you should be all set (plus XRemote plug-in), if not than you may want to look into USB-UIRT....
