need help with installation please!
Postby notelepek on Sat Jan 08, 2005 12:49 pm
hi guys, i downloaded xlobby2.zip from the link on the download page and tried to install it but my monitor just goes black and nothing seems to be happening. Could i have downloaded the wrong version? this is what was said:
The latest and greatest experimental version(constantly updated daily, use with caution)
thanks for your help.
notelepek
Postby emurr on Sat Jan 08, 2005 2:34 pm
Hello!
First of all you need to have the .NET framework installed on your computer.
Download:
http://www.xlobby.com/xlobby2pre14.zip
http://www.xlobby.com/xlobby2main.zip
You need to install the top file first, then the next file to update the installation.
The http://www.xlobby.com/xlobby2.zip is the file stevenhannah is constantly uppgrading to fix problems or to add features. This file you just copy into the xlobby folder to update it.
I reccomend you to install one of the excellent skins you will find in skins section in the forum.
emurr
Postby Arthur on Sat Jan 08, 2005 9:47 pm
Well, you just downloaded the latest version, it shouldn't be a problem.
You definitly need teh .net framework installed on your pc. Its a microsoft add on to windows. Seach microsoft.com for a free download.
Arthur
Postby BaddaBing on Sun Jan 09, 2005 5:01 am
Gee, this sounds familiar...
http://www.xlobby.com/forum/viewtopic.php?t=2626
Use the following files installed in the following order:
1] xlobby2pre14.zip - from the Xlobby download page
2] xlobby2main.zip - from the Xlobby download page
3] xlobby2.exe - from the Xlobby download page
Unzip each file into your Xlobby directory. If prompted to overwrite click yes.
FYI, next time a quick search of the forum posts might be a good idea. :wink:
BaddaBing
Postby Colby on Sun Jan 09, 2005 5:50 am
Deja'Vu: the sensation you have done something before.
:wink:
its up and running.
Postby notelepek on Mon Jan 10, 2005 2:29 pm
thanks for the the help guys it is working.Would it be too much of a problem to include this info on the sequence of installation on the download or help page for newbies? i think it would prevent repeated query.
notelepek
Postby jowaldo on Mon Jan 10, 2005 4:20 pm
I think its probably time there is a new exe full set posted there.
