I am trying to use the copyfile plugin associated with the xscript plugin from the french team.
All is working but I cannot get the progress bar to work, it looks like it has one. I am currently using the BurnIt plugin and it works great with the progress bar.
I setup a text box with the ID of CopyGauge1 but I get nothing. CopyGauge just gives me 0% but the file is copying.
Part of the problem is that it is mainly in french so if anyone is using this and can help me out I would appreciate it.
Scott
