this gotta be a blunder from my side, but I cannot get XL to mount iso or img when using the internal mediaplayer. If I swith to zoomplayer then it mounts. Same machine, same skin so the setup is the same.
Does any here use the internal player with iso or img? If so what version of daemontools are u using?
I use the latest exe(2.0.8103.15) and use the def skin and didn't touch anything. Tried on xp and vista(no UAC)
For the command it uses
Goto screen -> mediaplayer
Play category item
player name: Empty
vaiable: Empty
It plays fine for TS, mkv and such but no go on the img or iso
Regards
