Playing audio file
Playing audio file
Postby a&m 350z on Tue Apr 19, 2005 11:58 pm
Ok I am a newbie, so this should be easy but I cant figure it out for the life of me. How do you play music. All my cd's are imported, covers and songs but it wont play. I am obviously missing something. Any help much appreciated.
a&m 350z
Postby Colby on Wed Apr 20, 2005 12:54 am
Did you add an audio player? (winamp) and does it automatically load when you start Xlobby?
I assume you are not trying to play actuall cds but audio files from your computer?
Youre close if you have a music database already. Are you using default skin?
Postby a&m 350z on Wed Apr 20, 2005 1:25 am
Yeah I am trying to play the files on my hd. I have the database but I guess I did not know I needed to add winamp. Can you point me to some directions on how to due this or give some help. I got my dvds working with zoom player.
a&m 350z
Postby a&m 350z on Wed Apr 20, 2005 1:26 am
Oh and I am still using default skin, thats the next step.
a&m 350z
Postby a&m 350z on Wed Apr 20, 2005 2:09 am
Got it working. Thanks for the help.
a&m 350z
How did you figure it out?
Postby XMediaTech on Thu Apr 28, 2005 8:17 pm
I am having the same newbie issue.
Mp3 and cover art is loaded now just need to get file types config to listen with Winamp
can anyone give a screen shot please?
XMediaTech
Postby BaddaBing on Thu Apr 28, 2005 9:12 pm
http://www.xlobby.com/files/badabing/files/Baddabings_Guide.pdf
page 18 will answer your question - but if your a newbie to XL then you miht want to look at the rest of it as well...
BaddaBing
U ROCK!
Postby XMediaTech on Fri Apr 29, 2005 4:54 am
Thanx BadaBING!
Awesome pdf
XMediaTech
