TV funtionality in Xlobby. How?
Postby englishpremier on Sat Jul 30, 2005 12:16 pm
I've done a ssearch and i'm quite supprised i haven't found it, but how do i get TV & PVR functionality in Xlobby?
I assume this is possible. I am usuing a hauppage WinTV Go, which has a software decoder and so isn't supported by SageTV.
Are there any beginners guides on setting up TV functionality in Xlobby?
Thanks.
englishpremier
Postby lar282 on Sat Jul 30, 2005 8:08 pm
if u like MediaPortal check the plugin section
Postby ingalls on Sun Jul 31, 2005 11:04 pm
the best way to watch tv in xlobby is to use xltv plugin. Works with progdvb or k!tv
ingalls
Postby englishpremier on Tue Aug 02, 2005 12:39 pm
argh, k!TV will not start it says there is no video overlay or something like that.
I'm usiing an nvidia fx5600 with the latest drvers. so i don't know what its talking about really.
My captre card ia a wintv go.
englishpremier
Postby Naylia on Tue Aug 02, 2005 1:55 pm
SageTV V3 will support software encoders and it is currently in public beta.
Naylia
Postby ingalls on Tue Aug 02, 2005 9:22 pm
did you read the help for k!tv?
Did you choose bt8x8 ou wdm?
ingalls
Postby summerall on Wed Aug 03, 2005 2:54 am
ingalls -
Will the k!TV xlobby plugin work if I have a wintv 150 tuner?
summerall
Postby dgemily on Wed Aug 03, 2005 7:52 am
summerall wrote:ingalls -
it's not a K!tv plugin :wink: for the moment it support K!TV 2.3.0.1 and progdvb 4.48. so if your card id supported by one of this software, it will works...
there is a new beta for K!tv, and it support pvr 150 but this version is not supported by xltv plugin (waiting for a real release not beta version)...
later,
dgemily
Postby ingalls on Wed Aug 03, 2005 10:13 pm
later,
exactly!
you can try first the betas on http://usuarios.lycos.es/forumdev/viewtopic.php?t=2918 then wait for a final version, chere you will have a new xltv version.
ingalls
Postby mzemina on Thu Aug 04, 2005 2:38 pm
What exactly is K!TV? I can't find an about section to translate as to understand the benefits/features of this plugin.
I've translated (through babel) some of the posts on the forum but wasn't able to gain enough overview on this plugin.
Mike Zemina
mzemina
Postby badubo on Thu Aug 04, 2005 2:55 pm
K!TV is not a plugin, it is a standalone application
http://www.kastortv.org/index.php?langue=eng
the plugin for xlobby that allows to control k!tv directly from xlobby (and its EPG) can be found there :
france.xlobby.com/plugins/xltv.zip
The doc is in english
badubo
Postby englishpremier on Sat Aug 06, 2005 11:37 am
I finanlly got K!TV to work somehow, problem is now, I have an issuse with xlobby.
Whenever i load xlobby, the splash screen comes up and everything loads, but then it dissappears. I checked under processes using CTL+ALT+DEL and i t is there using about 11MB but its interface is nowhere to be found.
(its not just that version of xlobby either, i unzipped another to a different drive to try to that and it does the same. This also happens in safemode too)
Whats going on here?
EDIT: Turns out its the xltv plugin that is causing the problems. xlobby works fine without that. doh!
englishpremier
Postby badubo on Sun Aug 07, 2005 6:54 pm
you must have the last version of xlobby2.exe and the related sdk
badubo
Postby C-moi on Sun Aug 07, 2005 7:38 pm
englishpremier
there is a skin named xltv with the plugin : it's a basic skin only to show you if all is right.
I think there is only 2 skins with xltv !
XMedia2 by sagitaz
http://www.xlobby-france.com/forums/ind ... topic=1007
and HeavyMetalXFR by Baddabing and dgemily add xltv integration
http://www.xlobby-france.com/forums/ind ... topic=1314
If you succed with K!TV, xltv will work ! read the xltv.doc
I wrote a tutorial but it's in french and only for progDVB !
http://france.xlobby.com/xltv.htm
C-moi
