I felt the need to create a new topic where this TV plugin can be well followed and monitor by all.
XCTtv is the name I gave this TV plugin project based on my other TV project CTpvr/CTtv. I was not expecting to get too involved but felt the need to kick start a TV-Plugin for Xlobby. Once I started coded and interfacing this plugin, I realized what amazing potential this Xlobby engine has. My hat goes off to Steven for a job well done.
::: Cards tested :::
• Hauppauge PVR-250/350. • Hauppauge PVR-250MCE
• Hauppauge PVR-250BTV • ATI E-Home Wonder
• Aver Media M150
::: Cards not yet tested :::
• Hauppauge PVR-USB2 • Adaptec VideOh
• Generic Conexant "Blackbird" • Provideo PV-258/259
• AVerMedia M172/M179 • NVIDIA MCE TV
App: Sample app that I wrote to kick start this project ( Only in HeavyMetal Skin for Now )
http://ctpvr.com/downloads/XCTtv.msi
Added features: Pause Mode(Time Shifting) FF/REW are not enabled yet and Skipping in Pause mode still need to be tweak. File Playback, Large screen mode almost full screen, Task bar should not show when starting TV or Playback.
If you had installed the previous version of XCTtv you should follow these directions:
You should delete the files from the last setup you had before you start with this new one.
5 Files all together
the 2 in the "XCTtv" plugin folder.
1 or 2 under the "HeavyMetal" folder ( XCTtv.xml, XCTtvLarge.xml )
1 under the "HeavyMetal\eventgroups" folder ( XCTtv.xml )
After deleting those files the installer should work out fine.
Another way to delete these files is to run the XCTtv installer and install. Then you run the installer again to get rid of the files. Then you run the installer again to install and that should do it.
Source:
http://ctpvr.com/downloads/xlptv.zip
This source is to the above app the works using a Dll based engine I created. The source to the Dll will not be made available. I will put together some docs to help any developers interested in contributing any help.
Two photos follow
Regards,
Carm.
