Xlobby V3 and Xliveshout
Postby lar282 on Thu Jun 10, 2010 8:23 am
Trying to get Xliveshout to work. First it didn't show up as a plugin but after adding xsoapwheater as a plugin it now shows up.
But now when entering the main screen of liveshout, Xlobby crashes. I tried both with Xlobby V3 and V2 and the same crash occurs?
Any here got the plugin working or has the source code?
please help. I wanna use ipradio and so tired of updating/changing url's all the time.....
e (JIT) debugging instead of this dialog box.
System.NullReferenceException: Object reference not set to an instance of an object.
at xLiveShout.xLiveShout.get_GenreEx()
at xLiveShout.Parser.VariableLookup(Match match)
at System.Text.RegularExpressions.RegexReplacement.Replace(MatchEvaluator evaluator, Regex regex, String input, Int32 count, Int32 startat)
at System.Text.RegularExpressions.Regex.Replace(String input, MatchEvaluator evaluator, Int32 count, Int32 startat)
at System.Text.RegularExpressions.Regex.Replace(String input, MatchEvaluator evaluator)
at xLiveShout.Parser.Parse(xLiveShout liveShout, String input)
at xLiveShout.xLiveShout.GetVariable(String name)
at xlobby2.Plugins.GetValue(String input)
at xlobby2.PicButton.drawImage(Graphics g, Control c)
at xlobby2.GdiDraw.DrawButton(PicButton ptemp, Graphics g, Control control)
at xlobby2.GdiDraw.DrawFormButtons(Graphics g, ArrayList buttons, Control control)
at xlobby2.GdiForm.DrawToGraphics(Graphics g)
at xlobby2.GdiScreenForm.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
xlobby2
Assembly Version: 2.0.8254.0
Win32 Version: 2.0.08254.00
CodeBase: file:///G:/xlobbyV2/xlobby2.exe
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Interop.ActiveHomeScriptLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///G:/xlobbyV2/Interop.ActiveHomeScriptLib.DLL
XPluginSDK
Assembly Version: 1.0.2817.26334
Win32 Version: 1.0.2817.26334
CodeBase: file:///G:/xlobbyV2/XPluginSDK.DLL
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Interop.X10
CodeBase: file:///G:/xlobbyV2/Interop.X10.DLL
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
DShowPlayer
Assembly Version: 0.0.0.0
Win32 Version:
CodeBase: file:///G:/xlobbyV2/DShowPlayer.DLL
msvcm80
Assembly Version: 8.0.50727.4927
Win32 Version: 8.00.50727.4927
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442db5b5/msvcm80.dll
Microsoft.JScript
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4927
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
xlobbydvdcopy
CodeBase: file:///G:/xlobbyV2/plugins/xlobbydvdcopy.dll
XoapWeather
Assembly Version: 1.2.2175.905
Win32 Version: 1.2.2175.905
CodeBase: file:///G:/xlobbyV2/plugins/XoapWeather.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
-ga3syru
xLiveShout
Assembly Version: 1.2.1.0
Win32 Version: 1.2.1.0
CodeBase: file:///G:/xlobbyV2/plugins/xLiveShout/xLiveShout.dll
XWeather
Assembly Version: 1.0.3023.23285
Win32 Version: 1.0.3023.23285
CodeBase: file:///G:/xlobbyV2/plugins/xweather/XWeather.dll
Interop.Shell32
CodeBase: file:///G:/xlobbyV2/Interop.Shell32.DLL
CustomMarshalers
CodeBase: file:///C:/Windows/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
DShowPlayerDVD
Win32 Version:
CodeBase: file:///G:/xlobbyV2/DShowPlayerDVD.DLL
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
enabled.
For example:
<configuration>
</configuration>
