I integrated some emulators in Xlobby but I'm not realy use all of them.
http://perso.wanadoo.fr/chezdgemily/play_games.rar
Here is my eventgroups “play games” for:
project64
- mame32+
- zinc
- zsnes
- VisualBoyAdvance.
you can take a look if you need...
here :
http://www.xlobby.com/forum/viewtopic.php?t=2003&start=0&postdays=0&postorder=asc&highlight=
is the thread about how to integrate MAME32+ ,is the same way for all other emulators (project64- mame32+- zinc- zsnes- VisualBoyAdvance.)
about zinc is a little bit different , for the command lines you need the number of every roms:
sfexj.zip set nomb=1
sfex.zip set nomb=2
sfexp.zip set nomb=3
sfexpj.zip set nomb=4
sfex2.zip set nomb=5
sfex2p.zip set nomb=6
sg2j.zip set nomb=7
rvschool.zip set nomb=8
jgakuen.zip set nomb=9
sr2j.zip set nomb=10
sr2.zip set nomb=11
kikaioh.zip set nomb=12
ts2j.zip set nomb=13
tgmj.zip set nomb=14
sncwgltd.zip set nomb=15
beastorizer.zip set nomb=16
psyforce.zip set nomb=17
mgcldate.zip set nomb=18
souledge.zip set nomb=19
souledgc.zip set nomb=20
tekken.zip set nomb=21
tk2b.zip set nomb=22
danceyes.zip set nomb=23
xevi3dg.zip set nomb=24
starswep.zip set nomb=25
myangel3.zip set nomb=26
your database should be like this:
- Code: Select all
<item>
<parameter>16</parameter>
<coverart>D:\zinc\roms\beastorizer.jpg</coverart>
<display>beastorizer</display>
<information>
<name>beastorizer</name>
</information>
</item>
for Mame32+we found an application that it scan your mame repertories' and build a xlobby database with the maximum of informations.
your pictures must have the same name of your roms with an extention ".png"(you can do spnashots with mame, press F12)
here is the application in French and in US:
http://france.xlobby.com/download/Rom_to_xml.raryou have to indicate the repertory where your roms folder, your pictures folder and where your database repertory are.
to do it: edit Rom_to_xml_US.vbs (right click and modify)
change those lines:
- Code: Select all
' Liste of roms files (deflaut directory) :
Rom_Path = "C:\Program Files\mame32+\roms\"
' List of all rom snapshots (default directory) :
Rom_Snapshot_Path = "C:\Program Files\mame32+\snap\"
' Roms Categories (default file) :
Rom_Type_File_Name = "C:\Program Files\mame32+\folders\Category.ini"
' Destination file :
Rom_XML_File= "C:\Program Files\Xlobbyfr\databases\Mame.xml"
it will create a database like this:
- Code: Select all
<database>
<sortorder>display</sortorder>
<sortable>
<sort>Types</sort>
<sort>RomInfo</sort>
</sortable>
<template>display</template>
<paths>
</paths>
<item>
<parameter>D:\Emulateurs\mane32plus\roms\1941.zip</parameter>
<coverart>D:\Emulateurs\mane32plus\snap\1941.png</coverart>
<information>
<display>1941 - Counter Attack (World)</display>
<produced>1990</produced>
<rom>1941</rom>
<Types>Shooter,Flying Vertical</Types>
<Construct>Capcom</Construct>
<RomInfo>Dispo.</RomInfo>
</information>
</item>
<item>
Later.
