Stills display in the Movies db (or any db with stills) is random. Which means you can sit there watching stills for a long time and never see them all even when there is only say 10 of them. Technically if I sit there long enough I should see each still the same number of times, but I've got other things to do...
So the request is... drum roll.... make the stills display starting image random, but after that step through the images either sequentially or do some kind of FIFO looping array so that we are garaunteed to see all the images before we see a duplicate.
Thanks for all your great work!
tsw
