In the default skin folder add a new folder Backgrounds2 and add background jpg images with resolutions of 800 x 600 or 1024 x 768. Restart xLobby when restarted xLobby will load images from the Backgrounds2 folder randomly until the images are completed or if you number them like background1, background2, etc they will load in order. It is still experimental. We want to add a few basic commands like adjusting time in between images, the ability start and stop images as well as reset to a default image. Eventually more advanced features that can fade or blend images, etc.
To stop the roatating image feature rename or delete the folder.
Any idea as to when this feature will be ready for use? Just a handfull of commands like start, stop, continuous looping and it would be ready to go.
And maybe multiple background folders.
